Activity Forums DaVinci Resolve HDMI output and 4.4.4.
  • HDMI output and 4.4.4.
    Posted by Thibault Carterot on October 19, 2010 at 2:28 pm
    Hello,
    I’m using a JVC DILA950 (RS25 in US in think), which accept 422, 444 and RGB through HDMI.
    But I think HDMI output via BM 3D+ card is limited to 422. So my question is :
    1°/ Does BM plan to update the output to 444 (if its even possible)
    2°/ Does it exist a converter doing HDSDI to HDMI 444
    Thnak you
    Config : Mac Pro 2010, 8×2,4Ghz, 16Go Ram, FX4800,GT120, Decklink 3D+, RED Rocket, system on Crucial SSD 250, 5x2to Seagate XT Raid0 drive, DaVinci Resolve 7.02
    Kristian Lam replied 15 years, 10 months ago 4 Members · 4 Replies
  • Thibault Carterot
    October 19, 2010 at 6:21 pm
    Ok, if found the solution,
    use HI5 converter from AJA.
    I’m buying it
  • Blase Theodore
    October 19, 2010 at 7:41 pm
    I thought decklink’s HDlink Pro does it via HDMI 1.3?
  • Denver Riddle
    October 20, 2010 at 7:39 pm
    This response from Albert Chu of BMD:
    This update to support HDMI 1.3 and 1.4 is only available on the HDLink
    DisplayPort 3D. I am under the impression this is due to updated and newer
    hardware on the HDLink DisplayPort 3D.
    and
    As far as I know, the HDLink Pro will only ever do 8 bit. But I’ll still be happy to re-log this request.
    The HDLink DisplayPort I assume uses the same mini display port popular on newer mac graphics cards and macbook pro. Please advise if this is correct. My apologies if this is a stupid question.
    I suppose the HDLink DisplayPort 3D would be the adapter to go for rather than the AJA.
    Cheers,
    Denver Riddle
  • Kristian Lam
    October 25, 2010 at 8:38 pm
    [Denver Riddle] “The HDLink DisplayPort I assume uses the same mini display port popular on newer mac graphics cards and macbook pro. Please advise if this is correct. My apologies if this is a stupid question.
    It uses a standard sized DisplayPort and not the mini version used by Apple.
    regards
    Kristian Lam
    Blackmagic Design
