Activity Forums Panasonic Cameras HDMI Output 25 or 50fps?
  • HDMI Output 25 or 50fps?
    Posted by Steve Mullins on October 6, 2020 at 9:07 am
    I have a gh4 with updated firmware and one without.
    Connected to a ATEM Mini Pro – both recording 4K 25fps internally (so only 8bit 422 available on hdmi out)
    GH4 without firmware:
    HDMI Rec Output
    -Bit Mode / Info Display / 4K Downconvert (set to 1080p)
    GH4 WITH firmware upgrade (more HDMI Rec Output options)
    HDMI Rec. control (greyed out – set to off)
    1080/25p Set. – 25p or 50p
    *** – now, do i set this to 25p or 50p – what is the GH4 without firmware set to? ***
    If i set it to 50p and the other is sending a 25p signal – will have major frame judder?
    Steve Mullins replied 5 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
