Activity › Forums › Apple Final Cut Pro Legacy › HDMI out only
  • Posted by Lawrence Bowden on March 29, 2012 at 1:10 pm
    Hi all,
    I’m wanting to add a 32inch Samsung 1080p TV into the mix with FCP. At the moment I’m running duel display monitors for bins, timeline etc.
    I only want to use the TV for full screen Viewing so clients etc can see it “all lovely and big”. I’m aware the blackmagic intensity will do the trick but it’s got loads of stuff with HDMI in etc that I simply don’t need. Does any one know of a streamlined graphics card that will kick the signal out? Perhaps buying a DVI card and converting the signal to HDMI would be better?
    All suggestions greatly appreciated. Really a simply HDMI out PCI card would be great.
    Cheers,
    Lawrie
    Bret Williams replied 14 years, 6 months ago 4 Members · 3 Replies
  • Neil Patience
    March 29, 2012 at 1:48 pm
    I think the issue that you will have is that computer graphics cards and video IO cards are very distinctly different.
    Computer graphics cards dont adhere to video specification well, have issues with interlacing and all kinds of other quirks that can impact on what your client and you see.
    I would say that in order to make any kind of meaningful judgement about how your pictures look then you need to get a basic video based IO that interfaces properly with FCP.
    I think the BM intesity is pretty much one of the cheapest options to do this.
    best wishes
    Neil
    http://www.patience.tv
  • David Roth weiss
    March 29, 2012 at 2:08 pm
    [Lawrence Bowden] “I’m aware the blackmagic intensity will do the trick but it’s got loads of stuff with HDMI in etc that I simply don’t need.”
    You clients are well worth the $200, and should you ever decide to get a true broadcast monitor the Intensity will serve you well.
    Meanwhile, Neil is correct, a video signal is whole different enchilada from the signal out of your computer graphics card.
    David Roth Weiss
    ProMax Systems
    Burbank
    DRW@ProMax.com
    http://www.ProMax.com
    Sales | Integration | Support
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Bret Williams
    March 29, 2012 at 4:06 pm
    A PCI graphics card with HDMI (for example the PC Radeon 5770 flashed to Mac) will still cost you around $200. Go for the intensity pro.
