Activity › Forums › AJA Video Systems › HDMI input from MacBook
Posted by Marc Colemont on May 1, 2010 at 11:53 amI’m trying to capture the DVI output through an HDMI cable from my Macbook Pro.
When I connect, the MacBook does see the AJA Ki Pro with 480i, 720p, 1080i settings 50/60Hz.
But when I set any of these, the AJA Ki Pro displays ‘No Input’
I assume the MacBook outputs ‘RGB’ colorspace. Could this be related to the fact it sais No Input?
Has anyone of you successfully captured computer signals through HDMI? I don’t find setting to select the colorspace either…
Thanks for your help.Kenneth Wedmore lund replied 15 years, 6 months ago 6 Members · 20 Replies -
Jeremy Garchow
May 1, 2010 at 9:56 pm[Marc Colemont] “Could this be related to the fact it sais No Input? “
Sorry, the Macbook is not outputting video that the Kipro will record.
What are you trying to do?
Jeremy
Marc Colemont
May 1, 2010 at 11:02 pmI use 4 AJA Ki Pro’s for multi-camera recording.
For corporate shows, I want to feed also the HDMI (DVI) through one of them, so we can capture the Keynote/Powerpoints, and use the AJA as a convertor to use the HD-SDI out to the video mixer.
The same goes for on location shooting. I have a training video coming up were I need to capture the computer screen. I use not camtasia software screen recording, but it’s a hassle converting properly and syncing in post.
One device I was hoping which could do it all. But the AJA Ki Pro does not want to read HDMI RGB, and the MacBook Pro does not has a setting to output YUV color space.
AJA support, in case you read this. This would be soooo cool. Colorspace conversion is not so hard to do inside an FPGA which I guess is inside the Ki Pro. Many thanks in advance if this would be possible. I would be first in line to beta test it. -
Jeremy Garchow
May 2, 2010 at 12:41 amGot it. It’s not that easy unfortunately. KiPro can detect rgb vs yuv.
What you need is a can converter that will take the dvi and turn it in to baseband video so the KiPro understands that signal.
Jeremy Garchow
May 2, 2010 at 2:49 amScan. I meant scan converter…..that can.
iPhone. Where the typo reigns supreme.
Marc Colemont
May 2, 2010 at 8:54 amThen I will have to use a device like an MXO, but it’s a pitty just because the colorspace isn’t detected.
AJA team: any plans on this? -
Gary Adcock
May 2, 2010 at 3:04 pm[Marc Colemont] ” But the AJA Ki Pro does not want to read HDMI RGB, and the MacBook Pro does not has a setting to output YUV color space. “
that is not the issue.
Your computer does not output a standard Video signal and AJa devices only see SMPTE / EBU video signals.
Occasionally you can do this if you have a computer that can correctly output 1080 at 24/25/50/60 hrz (depending on where you live in the world).
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows for the Digitally Inclined
Chicago, ILhttps://blogs.creativecow.net/24640
Jeremy Garchow
May 2, 2010 at 3:34 pmDude, it’s not the color space. It’s the DVI signal. Like i said before the ki will auto detect rgb vs yuv over hdmi.
You need a scan converter. This is not magic.
Charles Wannop
July 7, 2010 at 1:38 amWhile I realize it may be a bit late now, I have been looking at the same setup for seminars here in Australia… found this
https://blackmagic-design.com/products/dviextender/
Any thoughts from the herd?
Charles. -
Charles Wannop
July 30, 2010 at 12:28 amI have just bought a Hall Research scan converter/switcher to partner with my Ki Pro. I can now record PC or Mac screen video from VGA or HDMI/DVI (or even legacy VHS in CV or S-Video). PowerPoint slides look beautiful in 720p, and not too bad even in SD (if the presentation is bound for web distribution I think SD is good enough and a 250 gig storage module will happily swallow a whole day’s presentations).
Happy Camper,
Charles.
