Activity › Forums › Apple Final Cut Pro Legacy › HDMI (from directv dvr) to final cut… recommended capture card/device? hdmi to firewire
Posted by Andy Levine on April 26, 2013 at 7:11 pmi am trying to capture to final cut from my directv dvr.
i’m, guessing that i need a capture device. a friend said i should be able to find such a device for under $100.
i’m going into my imac, firewire port.
thanks
-andy
Ht Davis replied 11 years, 5 months ago 5 Members · 13 Replies -
Shane Ross
April 26, 2013 at 7:32 pmNope. The only options for converting capturing HDMI that connects to your computer via firewire are:
AJA IOHD. Discontinued, but when sold, cost $3500. Might find one used…but nowhere near $100.
MOTU V4HD. Also discontinued, but ran about $2000.
Those were the ONLY IO devices for FCP that captured HD and connected via Firewire.
If you have a Thunderbolt port, you have better options.
Decklink Ultrastudio Mini Recorder:
https://www.bhphotovideo.com/c/product/892453-REG/Blackmagic_Design_bdlkulsdzminrec_Ultrastudio_Mini_Recorder.html$140. But again, you need Thunderbolt.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Bret Williams
April 26, 2013 at 8:40 pmLikely wouldn’t work anyway because of the copy protection built into the HDMI signal.
Andy Levine
April 26, 2013 at 9:00 pmwow thanks for that shane!
i just noticed that i have component out coming from the dvr does that change things at all?
my imac (MC812LL/A) has a ‘thunderbolt port’ but something tells me it is more like a mimi display port rather than a fully-functional thunderbolt port on this model. hopefully i’m wrong. might you know?
thanks again.
-andy
Shane Ross
April 26, 2013 at 9:38 pmComponent out might bypass the copy protection Bret is talking about. But your port is a Mini-Display port…not Thunderbolt…so nothing will work in terms of capturing for FCP or any NLE.
But there are EYETV options for capturing as H.264. I use this for over the air broadcasts playing on my computer. Because I don’t have cable.
Shane
Little Frog Post
Andy Levine
April 26, 2013 at 10:08 pmhmmm…
these are already recorded programs on the directv dvr.
so since my imac has mini display, not thunderbolt the hdmi plan is no good. but is the component to firewire an option?
thanks again.
Shane Ross
April 26, 2013 at 10:13 pmNo, I was mistaken. Your computer does have thunderbolt.
And no, there are no Component to firewire options, other than the two discontinued items I mentioned.
Shane
Little Frog Post
Andy Levine
April 26, 2013 at 10:21 pmok so hdmi is workable to the thunderbolt but there is some kind of drm that could be a problem. i am currently able to record to my set top box dvd recorder from the hdmi so maybe the drm isn’t an issue with these recordings.
Andy Levine
April 26, 2013 at 10:24 pmwhy not usb then, this one is only $100:
Blackmagic Design Video Recorder USB Capture Device
Shane Ross
April 26, 2013 at 10:25 pmThat device only records SD H.264s. Trust me, I have it. The HD one is $500…but still only captures as H.264
Shane
Little Frog Post
