Activity › Forums › Event Videographers › Hdmi extenders
Hdmi extenders
Posted by Ricardo Marty on February 25, 2017 at 1:40 amI need to stream an event I only have hdmi cameras. I got two good hdmi 2, 15ft cables but I need at lease 30ft. {2 cameras}
Will extenders do the job with good video quality. I don’t want to use cat 5 as the end terminal.Please advize
Ricardo Marty
Ricardo Marty replied 9 years, 6 months ago 4 Members · 10 Replies -
Vincent Simoneau
March 2, 2017 at 1:10 pmHi Ricardo,
I would suggest the following:
4K: https://gefen.com/kvm/ext-uhd-cat5-elrpol.jsp?prod_id=15119
1080p: https://gefen.com/kvm/gtb-hdbt-pol-blk.jsp?prod_id=11041
Just make sure that the sampling rate is to your liking, however if it’s for viewing, Gefen is one of the best in the biz.
Hope this helps
Cheers -
Ricardo Marty
March 4, 2017 at 4:01 amThanks ill check them out. The signal is going into laptop with a softare vision mixer via magwell usb 3 hdmi capture dongle to be webcasted
Thank you
Ricardo Marty
Jeff Pulera
March 8, 2017 at 3:55 pmHi Ricardo,
I have 50′ HDMI cables I got from Amazon and they work fine. Was out on the job where the intention was to use HDMI over Cat6 extension technology from camera to switcher (Newtek TriCaster) but the TriCaster would NOT accept the signal, although going straight into a monitor worked fine, handshake issue??
Since we could not use the Cat6 solution (baluns) we needed to use an HDMI cable, but would not reach. Ran to the store and got a simple female-female HDMI connector to join two HDMI cables together and that worked great. The store charged $40 for that simple little connector, ridiculous! I took it back, then ordered a multi-pack of connectors from Amazon for like $6 to keep in my kit.
Some longer HDMI cables actually have signal repeaters built into the cables.
On a positive note, we were able to use the HDMI baluns from switcher to projectors and that run was twice as far and worked perfectly, so the balun technology was sound, just somehow not compatible with my switcher. I believe something to do with EDID – switcher and camera source could not handshake and agree how to communicate!
Whatever you go with, test test test before the event. I was unable to test since another person from out of town was bringing the baluns and they worked fine is his testing…but he did not have my switcher to test with. I think they were Monoprice baluns (HDMI over CAT cable).
Jeff
Ricardo Marty
March 13, 2017 at 5:08 pmhdmi cable seem to expensive as compared to cat and sdi cables and they don’t lock to well. Ill look for those hdmi with inbuilt reapeters. Do you have a link?
Thank you
Jeff Pulera
March 13, 2017 at 5:24 pmOn Amazon, search “HDMI cable booster” and several come up in different lengths, different vendors
Ricardo Marty
March 18, 2017 at 8:39 pm[Jeff Pulera] “HDMI cable booster”
They look good. hope it they work from camera to magewell to computer-
RM
Sam Hones
March 22, 2017 at 7:26 amHave a look for
Mini SD-SDI HD-SDI 3G-SDI to HDMI Video Audio Converter Adapter 1080P DC 5V-12V
get one HDMI to SDI and another for SDI to HDMI. Yes, you’d run a BNC cable between but it works well and over great distance. You have just one cable as opposed to two Cat5/6 and at £20 per adapter is quite a bit cheaper. I got the idea from church setups and then tried it myself. -
Sam Hones
March 22, 2017 at 7:34 amMay I ask you what program you use on the laptop. I have both a Magwell (not batched as such but does the same job (XI100D UVC USB3.0 1080P 60FPS HDMI Video Capture Dongle)) and a Startech ( (USB 3.0 Video Capture Device – HDMI / DVI / VGA / Component HD Video Recorder – 1080p 60fps). They run on a Asus based desktop machine so I had to get a compatible Startech USB3 card else it won’t work, but it has input options of: composite VGA, HDMI s-video. I use it to capture output from someone’s laptops powerpoint presentation shown on projector. iSPY will see it and lets you attach a sound channel coming from elsewhere. Fine for viewing – recording in iSPY is problematic as only 10FPS
Ricardo Marty
March 22, 2017 at 7:12 pmCurrently vidblaster 4.11 and livestreamstudio free. I use two usb to hdmi magwell magwell dongles.. using an asus rog laptop
Ricardo Marty
March 22, 2017 at 7:15 pmI prefer not to use cat cables will be ordering some long hdmi cables with inbuilt extenders to see how they work.
Thank you for your input
