Activity Forums Blackmagic Design HDMI DVD
  • Posted by Bruce Fraser on June 6, 2008 at 7:51 pm
    I have a DVD I need to get some clips from. I have a Panasonic DVD D52 player but I can not get the video to be seen by the Multibridge pro through HDMI. (I’m capturing BM 10 bit, non-controllable device) When I bypass the Multibridge the video plays fine to the monitor. I have the Decklink control panel on my mac set to HDMI Video & HDMI audio for the input.
    Why won’t the HDMI play through? It did with the camera.
    Bruce
    MacPro 3ghz Quad
    10g RAM
    FCP 6.0.3
    Kristian Lam replied 18 years, 3 months ago 3 Members · 4 Replies
  • Will Salley
    June 7, 2008 at 5:24 pm
    Is it copy protected?
    Primary System Info
    Mac Pro 2×3.2 Quadcore – 10.5.3 – QT 7.4.5 – 6MBram – nvidia8800GT – SATA internal & external storage – Blackmagic Multibridge Pro (v6.7)- Open GL 1.5.6 – Wacom Intous2 tablet
  • Kristian Lam
    June 9, 2008 at 9:00 am
    It’s most likely copy protected and we don’t pass through or capture copy protected HDMI streams.
    Unfortunately, most DVD players will encrypt the HDMI output even if the disc is not copy protected.
    regards
    Kristian Lam
    Blackmagic Design
  • Bruce Fraser
    June 9, 2008 at 4:07 pm
    No, it’s not copy protected. I ended up using another DVD player to get the job done. I’ll try the component out and see what happens. That kind of sucks that they encrypt that output.
    Thank you for the help,
    Bruce
  • Kristian Lam
    June 19, 2008 at 5:07 am
    Yes, it’s quite a shame. We’ve tested quite a few DVD plays with HDMI outputs and almost all of them encrypt the HDMI port output even when running your own non-protected disc.
    regards
    Kristian Lam
    Blackmagic Design
