Activity › Forums › DSLR Video › HDMI capture w/dslr
HDMI capture w/dslr
Posted by Ted Irving on March 3, 2011 at 12:22 pmis anyone out there capturing DSLR video from the HDMI out into a blackmagic or kona card? if so what are the pros & cons?
Ted Irving
Content Freelancer
Media Instructor
http://www.tedtv.tv
tedirving@yahoo.comDeleted User replied 15 years, 5 months ago 4 Members · 3 Replies -
Phil Balsdon
March 3, 2011 at 9:14 pmIf you are capturing from a Canon you won’t be capturing a clean camera output but the image you see in the viewfinder, ie superimposed camera info etc.
I believe the only HDSLR a clean camera out can be captured from via HDMI is the Panasonic GH2.Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
https://www.steadi-onfilms.com.au/ -
Shane Ross
March 4, 2011 at 10:30 amBEFORE it was recorded? As in a raw feed from the camera? As Phil said, you can’t do that. Not with the Canon’s anyway.
AFTER it was shot? Zero benefit in any way. You’ll be converting to ProRes, and will have to do it in real time, manually. And you will not get any usable timecode. If you take the card and use the Log and Transfer method, you still get ProRes files, but you also get a reel number and time of day code, and the ability to re-import if you lose a drive or want to revisit a cut.
It would actually be WORSE to use a capture card.
Shane
Read my blog, Little Frog in High Def -
Deleted User
March 6, 2011 at 5:17 pm[Phil Balsdon] “… I believe the only HDSLR a clean camera out can be captured from via HDMI is the Panasonic GH2. …”
Hi Phil: You can record a GH2’s clean/uncluttered 60i (or 50i PAL) live HDMI video output on an external recorder, but its clean/uncluttered 24p live HDMI video output is problematic.
See:
https://www.dvxuser.com/V6/showthread.php?233354-PAL-or-NTSC-GH2-for-HDMI-recording&p=2202051&viewfull=1#post2202051
https://www.dvxuser.com/V6/showthread.php?237584-HDMI-Capture-Problem-SOLVED-AviSynth-RULES!—
