Activity › Forums › DaVinci Resolve › Hdmi capture in resolve
Posted by Ricardo Marty on September 8, 2016 at 2:49 pmI have some dv tapes that I need to import into resolve . Will resolve (cs6) handle any hdmi capture device without the media express software?
Can anyone recomend a device)
I am currently using 12.5 resolve and a laptop
Thank You.
Ricardo Marty
Ps the intensity pro devices will not work on my laptop
Ricardo Marty replied 9 years, 11 months ago 2 Members · 7 Replies -
Hector Berrebi
September 8, 2016 at 3:15 pmhey Ricardo
bit more info would help.
what’s the laptop model?
does it have USB3?Intensity is probably your only option into resolve… why won’t it work on laptop?
did you have any device in mind?
As far as I remember Resolve only supports Black Magic hardware for capture.
you can maybe capture to a different software ?hector
Ricardo Marty
September 8, 2016 at 3:30 pmI have an asus g752. It has usb 3 and 3.1 plus thunderbolt 3
A friend loaned me a usb 3 bm device but the system did not see it. Usb are working fine.
Thank you
Hector Berrebi
September 8, 2016 at 3:36 pmIntensity I assume?
it should work.
how about this?
https://www.bhphotovideo.com/c/product/892453-REG/Blackmagic_Design_bdlkulsdzminrec_Ultrastudio_Mini_Recorder.html/prm/alsVwDtlshould also work
BM product page says PC/MAC -
Ricardo Marty
September 8, 2016 at 3:41 pmI read about but i am hesitant because its also bm and cant use as playback with resolve like the intensity should. I might give it a try if i can return it if it doesnt work.
Hector Berrebi
September 8, 2016 at 3:57 pmor better. make it work 🙂
both should work on your laptop (i see no reason otherwise)
its maybe a driver, version, OS thing.did you try installing Desktop Video (instead of ME) and checking if comp/resolve recognizes your device then?
