Activity Forums Blackmagic Design HDMI capture
  • HDMI capture
    Posted by Mike Moncrief on March 21, 2010 at 3:06 pm
    Hello,
    I am new to the Blackmagic family.. Sorry about the newbie question.. Anyway using a Multibridge Pro with an Mac Pro running FCP 6.06.. My question is can i capture directly into FCP using the HDMI input ?? If so what do you need to do to tell FCP to see the the HDMI in on the Blackmagic ?? Easy setup ???
    Thanks to all..
    Mike M.
    Mart Manic replied 16 years ago 3 Members · 2 Replies
  • Callum Mclay
    March 22, 2010 at 11:23 pm
    Hi Mike
    You can capture into Final Cut Pro using any of the inputs on your Multibridge. There are 2 main settings to use your Multibridge for HDMI capture.
    The first is in System Preferences>>Blackmagic>>Set input, where you tell the Multibridge which connection you want to use for capture, in this case “HDMI video and HDMI audio.” You also set many of the other hardware options for your Multibridge here.
    The second is, as you correctly say, in the Easy Setups for Final Cut Pro. You want to choose a Blackmagic Easy Setup, that matches the resolution of the video you wish to capture, and also your desired codec.
    For more information, please check out the user manual on our support pages here:
    https://www.blackmagic-design.com/fr/support/documentation/
    Callum McLay
    Technical Support Manager
    Blackmagic Design EMEA
  • Mart Manic
    September 16, 2010 at 2:17 pm
    Does not work. Maybe it’s the player? I’m doing a capture test with a burned blu-ray disk and FCP shows me only black in capture window (all the settings checked and corresponding to source), the same with Premiere.
    MacPro2008 octocore 2,8, 16GB ram, Multibridge Pro and a Philips blu-ray player.
