Activity Forums Blackmagic Design HDMI aspect ratio capture confusion
  • HDMI aspect ratio capture confusion
    Posted by Peter Humble on October 14, 2010 at 8:41 am
    I’m a newbie to BM so apologies if this is a bit 101…
    I’m attempting to capture for the first time using HDMI, an HDV tape with a Sony V1P. (previously I’ve always used firewire)
    The only time I can get FCP to “see” the deck is when I have my capture settings set to Blackmagic PAL – Apple Prores (HQ) or Blackmagic PAL – DV
    The problem is that this captures the native HDV 16×9 as a 4×3 image.
    I can’t seem to get any other setting to work.
    In attempting to troubleshoot I’ve played with my blackmagic settings. Currently they are as follows:
    I have played around with the above Input processing settings but the only time FCP can see the deck is when it’s switched to off…
    Any ideas?
    Adam Szabo replied 15 years, 10 months ago 3 Members · 5 Replies
  • Kristian Lam
    October 14, 2010 at 1:12 pm
    Hi
    Looks like your camera is down converting and sending SD video out of the HDMI connection. Check the camera settings and make sure down conversion is turned off.
    regards
    Kristian Lam
    Blackmagic Design
  • Peter Humble
    October 17, 2010 at 7:39 am
    Thanks Kristian,
    Well I just double checked and strangely there’s no ‘off’ setting. It only allows me to choose from squeeze, letter box or edge crop.
  • Adam Szabo
    October 19, 2010 at 7:18 am
    Could this be an HDCP conflict?
  • Peter Humble
    October 20, 2010 at 9:43 pm
    Hmmm, well if I had the foggiest what that acronym meant I might be able to answer 🙂
    …not the most technical person on this forum.
    So what does it mean?
    Any other suggestions anyone?
  • Adam Szabo
    October 21, 2010 at 9:02 am
    HDCP=High Definition Content Protection
    It is used to scramble data streams trough HDMI and DVI. If the target (usually a display) is not passing the test, it will only get low definition video.
    But it’s silly to protect a camera signal. No copyright and such. Normally is used between BD-player and HDTV.
