Activity Forums Blackmagic Design HDlink Pro – Interlace only?
  • HDlink Pro – Interlace only?
    Posted by Sean Donnelly on February 14, 2008 at 2:37 am
    I’ve been using an HDLink Pro for the last two weeks with an EIZO CG241W, and I’m noticing an interlace blur with fast moving images. I’m quite sure that I do not have the interlace simulation turned on, and this does not happen playing the same shot via the 2nd DVI port to the same display (I spent a lot of time doing an A/B between them) so I’m thinking it has to be the HDLink box. Is it possible that the interlace simulation is stuck in the on position? I have fed it many varieties of HD and SD SDI, with no change.
    Thanks in advance,
    -Sean
    Del Chapple replied 18 years, 4 months ago 4 Members · 4 Replies
  • Michael Gissing
    February 19, 2008 at 11:13 pm
    With no info on the edit system or file format you are looking at, the short answer is that Decklink cards correctly display interlaced images whilst a computer graphics cards DVI is not interlaced.
    Therefore if your footage is interlaced, the DVI is not displaying it correctly whilst the Decklink is.
  • Sean Donnelly
    February 21, 2008 at 1:04 pm
    Michael,
    As I said this is an HDLink box, NOT a decklink card, and the source material is coming from a camera’s HD-SDI out. This happens with any format (1080p24, 1080psf24, 1080p30, 1080psf30, etc.)
    -Sean
  • Andrew Huebscher
    March 9, 2008 at 7:15 am
    What build of HDLink are you running? Also, I’m using the same setup. I’m curious how you calibrated your Eizo. Did you use something like cineSpace to put a 3D LUT on the HDLink?
    Andrew Huebscher
    Los Angeles
  • Del Chapple
    May 6, 2008 at 7:10 pm
    I’ve noticed the interlace on 23.98psf material straight from a HDCamSR HD-SDI though a HD-Link DVI bridge also..
    del
    you cant hear my inner voice scream… can you..?
