Activity › Forums › Blackmagic Design › HDlink PRO doesn’t show any HD format to Panasonic TH-42PF20
  • HDlink PRO doesn’t show any HD format to Panasonic TH-42PF20
    Posted by Mikhail Puzyrev on March 10, 2011 at 10:58 am
    PAL is ok, when I switch to any 720 or 1080 format – plasma switch to no signal state. Source is Decklink Extreme 3D+, Software – Davinci Resolve.
    Mikhail Puzyrev replied 15 years, 6 months ago 3 Members · 4 Replies
  • Margus Voll
    March 11, 2011 at 5:58 am
    Maybe there is some frame rate issue ?
    Margus
    https://iconstudios.eu
  • Mikhail Puzyrev
    March 12, 2011 at 7:56 pm
    The same plasma connected to the HDMI output of Extreme 3D without HDlink works as intended – showing the picture in ALL the videomodes chosen at Davinci project tab. So it’s strictly HDlink issue which sends wrong signal to plasma. So I would like to know how to fix it.
  • Bob Zelin
    March 13, 2011 at 9:06 pm
    gee, why don’t you try putting a 29.97 signal on the monitor from your system, instead of 23.98, and see what happens ? How long will that test take you ?
    Then, if you have a Y Pb Pr output on your Decklink/AJA card, plug directly into your monitor with the CAV signal, and test that without the HD Link Pro, to see if that works.
    Bob Zelin
  • Mikhail Puzyrev
    March 13, 2011 at 10:15 pm
    Hello Bob!
    Straight from Decklink Extreme 3D from HDMI out to Panasonic DVI input – works great (from 1080 23,98 to 60, so 720, but I lose the ability to load 3D LUTs which HDLink Pro has.
