Activity Forums Blackmagic Design HDLink Pro 3D lut format
  • HDLink Pro 3D lut format
    Posted by Martin B. wehding on February 11, 2008 at 10:23 pm
    Hi
    We just got our HDLink Pro.
    Because we intend to use it with 3D luts I have been looking around for some info’s/documentation on formats and third party formats.
    We have cinecube(space) as well. Can that be used for generating 3D lut’s for the HDLink Pro?
    Anyone got some experience to share on this early stage:-)?
    Regards
    Martin Wehding
    Postproduction manager
    Fridthjof Film A/S
    Copenhagen
    Denmark
    Igor Litviak replied 18 years, 4 months ago 6 Members · 8 Replies
  • 8 Replies
  • Kristian Lam
    February 12, 2008 at 6:26 am
    Hi Martin,
    The current LUT formatwe support are Discreet’s 3dl and Iridas CUBE (.itx).
    We don’t support cinecube as yet but we can look into it.
    regards
    Kristian Lam
    Blackmagic Design
  • Andrew Huebscher
    February 13, 2008 at 2:02 am
    I also just received an HDLink Pro. I’m trying to import .3dl and .itx cubes, but the HDLink utility won’t recognize them. I changed the extensions, but then when I load it blacks out the output. I opened them in a text editor, and it appears the format used to create LUTs in the HDLink utility is different than the .3dl and .itx. Is there a conversion program or other trick necessary to make them work?
    Andrew Huebscher
    Los Angeles, CA
  • Kristian Lam
    February 13, 2008 at 3:58 am
    Hi Andrew,
    Could you let us download the LUTS you’re using?
    The LUTS created by the HDLink is not .3dl or .itx so it will look different. HDLink Pro currently only imports 3dl/itx but will not save the LUT in that format.
    regards
    Kristian Lam
    Blackmagic Design
  • Andrew Huebscher
    February 13, 2008 at 6:15 am
    Kristian,
    I’ve temporarily posted the Autodesk and Iridas LUTs at:
    https://andrewdp.com/autodesk-iridas.zip
    Please let me know once you’ve fetched it.
    The HDLink utility won’t recognize the .itx file. It sees the .3dl, but when I open that I get “Could not read lookup table file. The selected file was not in the expected format.” I am opening it via the “Load Table” button. This is using version 2.5, and it does recognize it’s a 3D box as I get the other 3D output curves.
    Andrew Huebscher
    Los Angeles, CA
  • Marcus Von holtzendorff
    February 21, 2008 at 9:19 pm
    I’m having problems with 3dlut import as well. From discreets format. The popup infor on the import tab says the file should have 1024 records, discreet 3dlut has 4015 (or there abouts). Anyhow, one of main reason for getting this box (hdlink pro) was for support of 3dlut import. How do I get my .3dl formated lut into the hdlink pro.
    Marcus
    Concordia university
    Montreal, Canada
    February 21, 2008 at 9:22 pm
    I too am having difficult importing 3d luts. I’m trying discreets .3dl format no luck
  • Steve Shaw
    February 29, 2008 at 10:14 am
    The Digital Praxis 3D Cube Builder will generate 3D LUTs (Cubes) to work with the HDLink Pro box.
    Soem example Cubes can be downloaded for free from the Digital Praxis webiste.
    http://www.digitalpraxis.net
    Steve
  • Igor Litviak
    April 19, 2008 at 5:31 pm
    Hi, Kristian.
    Maybe it is properly idea to publish right LUT formats on blackmagic-design site?
    After all, no strangers here – just write us link to one correct 3D LUT – and there will no more stupid questions.
    WBR,
    Igor Litviak
    Panorama Studio,
    St.-Petersburg
    Russia
