Activity Forums Blackmagic Design HDLink Pro 3D DisplayPort -> DVI-D
  • HDLink Pro 3D DisplayPort -> DVI-D
    Posted by Ben Richardson on March 13, 2011 at 3:37 am
    I’m getting an HDLink Pro to use with my DeckLink and JVC monitor which lacks SDI.
    I intend to upgrade the JVC at some point – likely with a DisplayPort compatible monitor – so it seems wise to get the DisplayPort model of the HDLink over the DVI-D model.
    Am I right in thinking that in order to get to the DVI-D input on my current monitor I simply need a passive DisplayPort to DVI-D cable or adapter? (HD only, no dual link for 2k currently required.)
    (A simpler question, if it’s the right one, might be: is the DisplayPort model “DisplayPort Multi-mode” compatible?)
    Ben Richardson replied 15 years, 6 months ago 2 Members · 2 Replies
  • Neil Sadwelkar
    March 14, 2011 at 4:34 am
    You could even get a DisplayPort to HDMI converter.
    Neil Sadwelkar
    neilsadwelkar.blogspot.com
    twitter: fcpguru
    FCP Editor, Edit systems consultant
    Mumbai India
  • Ben Richardson
    March 17, 2011 at 7:58 pm
    The answer was yes, the HDLink Pro 3D DisplayPort works perfectly with my JVC with both BMD’s recommended Monoprice Displayport to DVI-D adapter, and a cheap DisplayPort to DVI-D cable from Amazon.
    Which begs the question, who *wouldn’t* be better off buying the DisplayPort model of the HDLink over the DVI-D model?
