Activity › Forums › Blackmagic Design › HDLink on-set Panasonic 27F monitoring
  • HDLink on-set Panasonic 27F monitoring
    Posted by Qtmedia on November 13, 2005 at 8:29 am
    How can I fill a 23″ LCD display (1920 x 1200) with a signal from a Panasonic Varicam (720P) using the HDLink hardware and software utility? The input signal is HD-SDI from the camera directly.
    Kristian Lam replied 20 years, 10 months ago 3 Members · 3 Replies
  • Kaspar Kallas
    November 13, 2005 at 5:37 pm
    You cant!?
    -Kaspar
  • Qtmedia
    November 14, 2005 at 5:02 am
    Only solution so far is to use the ‘Zoom’ feature on the monitor itself!!
  • Kristian Lam
    November 14, 2005 at 5:50 am
    Kaspar is correct. HDLink is build for pixel-for-pixel monitoring of your HD signal and will not zoom your 720p video when connected via DVI-D.
    regards
    Kristian
    Blackmagic Design
