Activity Forums Blackmagic Design HDLink DOA?
  • HDLink DOA?
    Posted by Mathieu Marano on June 5, 2008 at 10:38 am
    I have a HDLink (not pro) that won’t let any signal go thru. I send 1080PsF23.98 to the Cinetal and everything os ok. Then I take the cable, unplug from the Cinetal, plug into the HDLink and…nothing. My HDLink is pluged in my Panasonic plasma TV via HDMI.
    I also have a HDLink Pro in another room. It’s plugged in single link HD-SDI and feeds an LCD monitor. I tried to change the HDLink for the HDLink Pro but it didn’t work either.
    Any clue?
    Mathieu Marano
    online editor – motion graphics – Post-prod director
    Directeur technique de post-production
    Le Bureau de post production
    Administrator of the Montreal Final Cut User Group
    http://www.finalcutmtl.org
    Callum Mclay replied 18 years, 2 months ago 3 Members · 3 Replies
  • Kristian Lam
    June 5, 2008 at 2:03 pm
    Hi Mathieu,
    What is the status of the LED lights on the HDLink?
    Does the HDLink Utility respond when you connect a host computer via USB to the unit?
    regards
    Kristian Lam
    Blackmagic Design
  • Mathieu Marano
    June 5, 2008 at 2:34 pm
    Yes it does. The red LED flashes and I have access to the 1D LUT thru the HDLink Utility. But I can’t gat the signal through like I do with the HDLink Pro .
    Mathieu Marano
  • Callum Mclay
    June 5, 2008 at 8:59 pm
    Hi Mathieu
    The HDLink and the HDLink Pro do not support as many formats over HDMI as they do over DVI-D. Please look at the supported HD formats here:
    https://www.blackmagic-design.com/products/hdlink/techspecs/
    The formats for HDMI are:
    1080i50, 1080i59.94, 1080i60, 720p50, 720p59.94 and 720p60.
    Have you tried plugging your HDLink into a DVI-D display while playing 23.98psf ?
    Callum McLay
    Technical Support Consultant
    Blackmagic Design EMEA
