Activity Forums Blackmagic Design HDLink – autoswitch input
  • HDLink – autoswitch input
    Posted by Christopher Tay on October 11, 2008 at 3:00 am
    Does anyone know if the HDLink will automatically switch itself to the input signal ?
    For example if I have it setup with dual BNC for HD 4:4:4 monitoring, will it be able to automatically switch between a single link SD/HD and dual link HD input ?
    I’m using the HDLink to feed to a HDMI projector and I will be switching between PAL 4:2:2 and HD 4:4:4 so just wanna know if the HDLink will autoswtich as it’s going to be placed up there close to the ceiling with the projector.
    Thanks.
    -chrispy
    Callum Mclay replied 17 years, 10 months ago 2 Members · 1 Reply
  • Callum Mclay
    October 17, 2008 at 10:05 am
    Hi Christopher
    Both the standard HD Link and the HD Link Pro will auto switch their input depending on whether you input Single link, Dual link, or in the case of the HD Link Pro 3 Gb/s SDI.
    Hope this helps!
    Callum McLay
    Technical Support Consultant
    Blackmagic Design EMEA
