Activity Forums Blackmagic Design HDLink and fimstream
  • HDLink and fimstream
    Posted by Michael Brennan on November 23, 2005 at 1:41 pm
    Tested this again yesterday.
    SRW1 with filmstream 4;4:4 into HDlink into apple.
    Picture is black crushed and extremely contrasty.
    Reset to unity then the familiar green flat image appears.
    Correct this with a few tweaks to get in tht eball park.
    SO whats up with the factory installed LUT am I missing something?
    Mike Brennan
    Luke Maslen replied 20 years, 10 months ago 2 Members · 1 Reply
  • Luke Maslen
    November 24, 2005 at 3:43 am
    Hi Michael,
    If you have found settings that work well, click on the Save Table button so you can reuse them later if the following suggestion doesn’t help.
    Are you using the HDLink default setup or have you chosen the Viper LUT. To choose the Viper LUT, click on the Load Table button, then click on “Built-in Table” and select Viper Filmstream Gamma Correction from the pulldown menu.
    Does this help?
    Regards,
    Luke Maslen
    Blackmagic Design
