Activity Forums Apple Final Cut Pro Legacy HDCAM SR – 2 Questions
  • HDCAM SR – 2 Questions
    Posted by Seawild on June 25, 2008 at 7:49 pm
    Hello Folks,
    1) Does a HDCAM tape that is labeled 29.97 run fine at 59.94 and visa versa? Are they the same thing? And if so why are there 2 choices?
    2) Can the HDCAM SR deck be play back “single link” ( using only one SDI, BNC 50 ohm cable )if the tape is 4:2:2? Or must the HDCAM SR desk always be outputting “Dual-Link”. ( using 2 BnC cables ).
    (I know the regular HDCAM deck will play out a single SDI cable)
    Chris
    Seawild replied 18 years, 2 months ago 2 Members · 2 Replies
  • Gary Adcock
    June 25, 2008 at 8:22 pm
    [chris rogers] “Does a HDCAM tape that is labeled 29.97 run fine at 59.94 and visa versa? Are they the same thing? And if so why are there 2 choices?”
    be VERY careful.
    it depends on which SR deck, the latest models of SRW1 and 5800 can do 1080 60p (at 59.94) and 60i
    1080 60p is a dual link connection,so check to make sure what System . Line . Format is set to.
    Traditionally 29.97 is considered the default HDcam format for playback, stick with this for safety.
    [chris rogers] “Can the HDCAM SR deck be play back “single link” “
    YES it can even playback 444 material as Single link- this is setup in the secondary outputs
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
  • Seawild
    June 25, 2008 at 8:54 pm
    Cool, thanks so much Gary!
    Chris W. Rogers
    Post Supervisor
