HDCAM SD capture settings
Im using a HDW-1800 HDCAM deck to capture some SD footage. The deck has a built in down converter, and i am able to hook it up to my Aja Io via composite connection. I am able to see video when i start logging but the motion is very blurred, just wondering if anyone knows the correct video setting to have on my final cut and the deck.
The settings im using currently are:
Sequence Preset: Uncompressed 10-bit NTSC 48 KHz
Capture preset: AJA Io: Composite 10-bit NTSC US 48 kHz
