Activity › Forums › Apple Final Cut Pro Legacy › hdcam ntsc to hdcam pal
  • hdcam ntsc to hdcam pal
    Posted by John Dicarlo on June 16, 2009 at 2:19 am
    Hi All,
    Not quite sure where to post this since it’s really not an FCP issue. And forgive me this is my first time posting.
    I’m taking a 10 bit uncompressed NTSC 1920×1080 23.98 QT with 4 channel audio in an FCP timeline and rolling it to HDCAM PAL.
    The problem I’m havng is as follows. I can easily run the SDI signal into a Folsom or Leitch for the standards conversion to 50i. The problem is the audio must be broken out separately analog.
    Again, I can make that analog patch easy enough. But, the audio drifts.
    If the clip was short it probably wouldn’t be an issue but, its a feature film 01:34 mins.
    Any suggestions to keep audio in sync would be greatly appreciated.
    -Cheers.
    John Dicarlo replied 17 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
