Activity › Forums › Apple Final Cut Pro Legacy › HDCAM mastering – Sony M2000 problem
  • HDCAM mastering – Sony M2000 problem
    Posted by Mark Rodway on February 26, 2008 at 9:36 pm
    I’m attempting to lay off to HDCAM from my 1080 timeline and although in straight record from the timelinethe recording is fine – when I attempt to edit to tape it looks to be laying down fine – but on reviewing the tape it’s just garbled multicoloured squares but correct audio.
    Has anyone any suggestions???
    I’m running FCP 6.0.2 – Timeline 1920 x 1080 PrResHQ – No Field dominance
    Blackmagic HD extreme card with the latest drivers.
    Laying off onto Sony M2000.
    Michael Gissing replied 18 years, 7 months ago 4 Members · 6 Replies
  • Mark Raudonis
    February 26, 2008 at 9:54 pm
    You realize that the SONY DVW-M2000 is a standard def deck NOT capable of recording HD video?
    Mark
  • Eric Hansen
    February 26, 2008 at 10:06 pm
    yes, but the HDW-M2000 is an HDCAM record deck.
    make sure the deck Reference is set for INPUT when doing an insert edit.
    e
    4 G5s, OSx 10.4.11, Final Cut 6.0.2, Kona LH (v5.1)
    Xsan: Xserve 2.0 G5, 3GB RAM, 2 7TB Xserve RAIDs, Sanbox 5200
    Quantum SDLT600A
    decks: Sony HDW-M2000/10 HDCAM, HVR-M10U HDV with HD-Connect, DSR-1500 DVCAM, UVW-1800 BetacamSP
    MacBook Pro: 2.33, 2GB RAM, OSx 10.4.11, Final Cut 6.0.2
    cameras: Panasonic HVX200, Sony FX1 and A1U, Arri S/B 16mm
    skis: Volkl Gotama 183s with 914s and Lange Fluid 120 boots
  • Mark Rodway
    February 26, 2008 at 10:49 pm
    Eric,
    Thanks I’ll double check for that – and indeed it is a HDW – M2000 (I think I may have noticed if otherwise!!!)…. It looks like more than a sync issue though. I’ve left for the evening now – but I thought that I might check the settings on the deck – I’m 99% sure that 1080 25pfs was what it was showing…..
    Mark
  • Michael Gissing
    February 26, 2008 at 11:00 pm
    If your sequence is 25psf then that is the correct settings. However, try the 50i setting as well. I have had the same problem with that deck and it is both the reference input setting and the 50i 25psf setting.
    In my case I was 50i and the deck was set incorrectly to psf but it gave me the same garbled greenish blocking
  • Mark Rodway
    February 27, 2008 at 9:50 am
    Just to follow up with what was the issue……………
    Thank you Michael – I’d suspected it might be the 25 PfS / 50i issue as I said in a previous post – but your post pretty much confirmed that for me.
    What I found is that although my timeline was ‘progressive’ – Blackmagic doesn’t support 25Pfs – only 50i – hence the garbled picture on edit to tape. So the deck had to be set to 50i.
    A technical query – A ‘progressive’ (no field dominance) timeline – laid off onto tape at 50i – is that still technically progressive – as both fields are the same???????
    Many thanks for your input – everyone who has posted.
  • Michael Gissing
    February 27, 2008 at 7:33 pm
    Mark,
    The sequence bed is 50i and the material is 25psf in your case. That is still a progressive image. If your material was not psf then you would need to set field dominance to upper. Even if you set it to upper, it makes no difference to the image if it was shot 25 psf.
    As all my work is broadcast with some digital projection in small cinemas, I always use an interlaced sequence and that way I can have both 50i and 25psf in the same timeline. The roll credits look smoother to me in interlaced.
