Activity Forums Apple Final Cut Pro Legacy HDCAM into FCP 5 / Decklink
  • HDCAM into FCP 5 / Decklink
    Posted by John on July 27, 2005 at 8:32 pm
    I have a question:
    If I were using FCP 5, a Decklink HD Pro card and a ProMax 3.2TB External Array SATAMAXe, would I be able to capture in FCP using an “uncompressed” setting? OR – what codec would be best to record? This is for an HDCAM online edit.
    John K
    John replied 21 years, 1 month ago 2 Members · 2 Replies
  • Walter Biscardi
    July 28, 2005 at 3:06 am
    As long as the drives support the sustained throughput needed for capture / playback of the 1080i uncompressed footage, you’ll be fine.
    I run a Kona 2 with the Medea FCR2X Fibre Channel array and it’s plenty fast enough for 1080i uncompressed here. Check with ProMax on whether that array is spec’d for uncompressed 1080i work.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • John
    July 28, 2005 at 2:01 pm
    Hi Walter. Promax tells me it is specced for uncompressed 1080i work. I just wanted to hear it from a day-t-day user like yourself.
    John
