Activity Forums Blackmagic Design HDCAM footage to DVCPRO HD
  • HDCAM footage to DVCPRO HD
    Posted by Ron on April 9, 2006 at 6:03 pm
    I have HDCAM 1080 23.98p footage on a drive and want to convert it to DVCPRO HD 23.98
    but I only see
    DVCPRO HD 1080 50i
    DVCPRO HD 1080 60i
    Ron
    Ron replied 20 years, 1 month ago 2 Members · 2 Replies
  • Kristian Lam
    April 10, 2006 at 1:18 am
    Hi Ron,
    You should use the easy setups we provide. The one you’ll need is “Blackmagic HDTV 1080psf 23.98 – DVCPRO HD”. This will configure your capture correctly.
    If you don’t see the easy setups, then make sure the correct driver is installed. FCP 5 requires our v5.x drivers while Final Cut Pro HD 4.5 requires our v4.8.1 drivers.
    regards
    Kristian Lam
    Blackmagic Design
  • Ron
    April 10, 2006 at 2:37 pm
    I got a workaround
    thanks
    Ron
