Activity Forums Apple Final Cut Pro Legacy HDCAM 24p to 60i
  • HDCAM 24p to 60i
    Posted by Liam Lawyer on April 7, 2009 at 3:53 am
    Greetings all!
    I am working on a project that is going to be shot on HDCAM in 24p that will be for web and broadcast. For the broadcast side of things, I am unsure of the best workflow to get to 60i. I am slightly familiar with pulldowns but not sure when this should come into play?
    Should I load at 60i? (is that possible?)
    OR should I convert after cut is finished? And if that is the case, how to do?
    Also, I assume that ProRes 422 HQ is a good resolution to cut in considering I am on a slower drive setup? (and to save space)
    We are working with FCP 6.x on an 8 core MacPro.
    Thanks much for any help!
    Liam Lawyer
    Liam Lawyer replied 17 years, 4 months ago 1 Member · 1 Reply
  • Liam Lawyer
    April 7, 2009 at 4:41 pm
    Good questions:
    We are most likely using external esata drive
    We have a Kona 3 card for capture.
    Thanks for your help!
    Liam Lawyer
    -editor-
