Activity › Forums › Apple Final Cut Pro Legacy › HDCAM 24P to 25P
HDCAM 24P to 25P
Posted by Per Ottesen on September 9, 2006 at 2:46 pmAre there any who had some experience with the conversion from HDCAM24P to 25P ?
David Davidson replied 19 years, 9 months ago 4 Members · 7 Replies -
Jeremy Newmark
September 10, 2006 at 8:21 amYes, we’ve done a good amount of 24p to 25p as well as 25p to 24p. What are you trying to do. A little more info would be good, in order for us to help you.
best regards,
jeremy
Per Ottesen
September 11, 2006 at 12:09 pmThe film is scanned to 24P, and are needed to be up-conversed to 25P for broadcast purpose. I know that there has been some problem where the conversion just play slower, so there afterwards are a sync problem, but that was before Cinematools ver. 3.1.1 , which on the paper looks better.
How had You made the conversion from 24P to 25P ?
Will it be better to edit in 24P, and first at the end made the up-conversion ?
We are thinking of using a Kona3 card, but do You have any recommendations ?
Gary Adcock
September 11, 2006 at 9:13 pm[Per Ottesen] “I know that there has been some problem where the conversion just play slower, so there afterwards are a sync problem, but that was before Cinematools ver. 3.1.1 , which on the paper looks better.”
Per
the simple solution since you are working in FCP is to complete the project and make self contained QT file,and a AIFF audio file of the same content and then use CT to do the conform ONLY the video file from 24 to 25.if the 1% audio is an issue ( it should be)
create a 25p project and import the 25p file and the AIFF audio file.
place the Video file into FCP and then Delete the Audio from the video ( or make the video without audio)
add the AIFF audio file to the project.Edit to tape Via the KONA 3 card (just as Walter and I do) and your final tape will have 25fps with correct audio- no renders and only a few minutes extra.
Gary
( from IBC)
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
David Davidson
November 13, 2006 at 9:33 pmWhat technique do you use to take a 1080 25P (not PSF) sequence to 23.98?
David Davidson
Managing Director
solventdreams, llc
http://www.solventdreams.com
4222 santa monica blvd
los angeles, ca 90028
323 906 9700
info@solventdreams.com -
Gary Adcock
November 13, 2006 at 9:57 pm[David Davidson] “What technique do you use to take a 1080 25P (not PSF) sequence to 23.98?”
David
FYI if it was recorded in-camera it is always PSFThe fastest way to do this is a 25-24 conform in Cinema Tools then re-attach the original audio to the conformed clip.
gary adcock
Studio37
David Davidson
November 14, 2006 at 3:25 amThanks. The 25p is artificially created–not in the camera.
David Davidson
Managing Director
solventdreams, llc
323 906 9700
