Activity Forums Apple Final Cut Pro Legacy HDCAM 1080 psf 29.97 Capture Settings
  • HDCAM 1080 psf 29.97 Capture Settings
    Posted by James Palugod on August 20, 2009 at 9:26 pm
    Trying to find capture settings for HDCAM 1080psf 29.97 in Final Cut. Closest thing Easy Setup has is 1080i 29.97 or 1080 24 psf. Any suggestions?
    I tried using 1080i 29.97 Apple Pro Res 422. Video and Audio seem to fall out of sync.
    Also in my Aja Kona LHe control panel the SDI input is set to 1080i and I cannot change it. Should it be 1080p?
    James
    Joey Burnham replied 17 years ago 2 Members · 1 Reply
  • Joey Burnham
    August 21, 2009 at 4:10 pm
    Try 1080p59.94 it’s basically the same thing.
    Joey
