Activity Forums JVC Cameras HD100 question about PAL and HDV
  • HD100 question about PAL and HDV
    Posted by Brian Luce on October 23, 2007 at 10:22 pm
    The JVC HD100 shoots in a SD/HDV mode of 25p and 50p at 576. Is this a PAL signal or does the HDV codec make it agnostic?
    Suppose you originate in 25p/576 and output to DVD, will it play on standard DVD set top player? Can it play on a NTSC set?
    Damon Winters replied 18 years, 9 months ago 3 Members · 2 Replies
  • Tim Baker
    November 7, 2007 at 7:00 pm
    If I’m not mistaken here…once you output to the .mpeg compression for DVD…it should play just fine on any DVD player.
    Even most EU players are cross compatible with pal/ntsc as long they were made in recent years.
    Not sure about the other questions.
    Tim
  • Damon Winters
    December 1, 2007 at 1:22 am
    Hi, 25i or 25p 576 lines is PAL. it is all 50hz. But the DVD playback question – many now will play either PAL or NTSC. Just check because some large mfg’s will lock it to only NTSC. Lite on, Apex, many OEM players will play both.
