Activity › Forums › Adobe Premiere Pro › HD100 + PPro2
HD100 + PPro2
Posted by Redindian on May 16, 2006 at 11:54 pmTo edit ProHD from JVC HD100, does premier pro2 require any special plugins/updates or does it edit natively?
I know Cineform Aspect HD makes it faster to edit – but its a bit expensive for me right now –
Any other cheaper alternatives to Cineform Aspect HD? …DVFilm Raylight?
David Newman replied 20 years, 4 months ago 3 Members · 5 Replies -
Marcus Van bavel
May 17, 2006 at 2:17 pmDVFilm Maker can convert mpeg-2 files from the JVC HD100 into
1280 x 720 Raylight AVI’s. If you purchase Raylight you can
get a license for DVFilm Maker included so the total cost is
just $195. See https://dvfilm.com/maker -
Redindian
May 17, 2006 at 6:48 pmThanks MVB –
In HD100 prespective –
whats the difference between this Raylight/DVMaker+PPro2 combo ($195) and ConnectHD+PPro2 ($199)? -
David Newman
May 17, 2006 at 9:06 pmThey will have similar performance although Connect HD is not designed for Premiere Pro (it is targeted for VfW apps like Sony Vegas.) CineForm Aspect HD is designed for PPro and will be several times faster than Connect HD or RayLight, but yes it is $300 more. Connect HD can be upgrade to Aspect HD at anytime difference is current purchase prices.
– David Newman
– CTO, CineForm
– web: http://www.cineform.com
– blog: cineform.blogspot.com -
Marcus Van bavel
May 17, 2006 at 9:07 pm[redindian] “Thanks MVB –
whats the difference between this Raylight/DVMaker+PPro2 combo ($195) and ConnectHD+PPro2 ($199)?”Please check with Cineform but I believe Aspect HD is for Premiere and
Connect HD is for Vegas.Not sure I can give you a comparison, but they all work. Raylight is a newcomer.
Give them a try. -
David Newman
May 17, 2006 at 9:10 pmMarcus is correct. Connect HD is not targeted for Premiere. It does work, but offers only moderate acceleration under PPro2.0. Many customers do use it within Premiere, to our supprize really.
– David Newman
– CTO, CineForm
