Activity › Forums › Avid Media Composer › HD work flow
  • HD work flow
    Posted by Johnnycutit on September 26, 2005 at 12:04 am
    what is the common work flow for HD projects?
    can you capture and edit your HD material in SD at a low resolution to save drive space and reconform sequences in HD for online?
    is this as easy as it is in media composer? – ie batch capturing a sequence and reconforming at a higher resolution for online and output in the same project.
    or do you have to start a new HD project in the HD format you wish to reconform up to and open your SD sequences in the new HD format? hope that made sense.
    i have read little on work flow for HD – there seems to be nothing around – any help or links appreciated
    thanks
    Bill Stephan replied 21 years ago 2 Members · 1 Reply
  • Bill Stephan
    September 26, 2005 at 7:35 pm
    Lots of good info on 24p.com
    Bill Stephan
    Senior Editor/DVD Author
    USA Studios
    New York City
