Activity › Forums › Apple Final Cut Pro Legacy › HD vs. dvc pro hd
HD vs. dvc pro hd
Posted by Timebombtim on August 2, 2007 at 3:17 pmHD vs. dvc pro hd? what is the difference? pros/cons of both?
David Roth weiss replied 19 years, 1 month ago 6 Members · 5 Replies -
Walter Biscardi
August 2, 2007 at 3:40 pm[timebombtim] “HD vs. dvc pro hd? what is the difference? pros/cons of both?”
DVCPro HD IS HD, as is HDV and HDCAM and XDCAM HD and D5 and ProRes HD. They’re all HD.
If you’re asking the difference between Uncompressed HD and Compressed HD, that depends on the original source and what you’re mastering to. What are you shooting and what are you going to master to?
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
John Foley
August 2, 2007 at 3:56 pmHD is a common term for frame sizes other than 4:3. There are uncompressed HD, HDV and DVCPRO HD which fit those other frames sizes.
it is my opinion to call HDV a wannabe HD as it uses MPEG-2 Long GOP recording, but since Sony is fixated on using HDV as their HD of choice, it is leading many to disregard true quality of picture for convenience.
Once again, this is my opinion – only!
Please visit http://www.thefinalcutstore.com for all your Final Cut needs.
13
August 2, 2007 at 4:14 pm[FinalOne] “it is my opinion to call HDV a wannabe HD as it uses MPEG-2 Long GOP recording, but since Sony is fixated on using HDV as their HD of choice, it is leading many to disregard true quality of picture for convenience.”
HDV is HD, it is just a compressed format of HD
The definition of HD is anything larger then SD video, HDV video ether 1080 or 720 and therefor by definition is HD. When people say that HDV is not “real HD” or is a “wannabe HD” it makes them sound like they don’t know what HD is. Because by definition HDV is “real HD” Sure it is a compressed format of HD,
I don’t remember people complaining that DV was not “real SD” or that it was “wannabe SD” DV is just a more compressed format of SD then others. Just like HDV is a more compressed format of HD.
Chris Borjis
August 2, 2007 at 4:15 pm[FinalOne] “it is my opinion to call HDV a wannabe HD as it uses MPEG-2 Long GOP recording, but since Sony is fixated on using HDV as their HD of choice, it is leading many to disregard true quality of picture for convenience.”
All too true, but I’m not sure they could have made it work at such a low cost without doing it this way.
In my opinion HDV/Mpeg works fine for aquisition only.
David Roth weiss
August 2, 2007 at 5:57 pm[FinalOne] “HD is a common term for frame sizes other than 4:3.”
Nope, the resolution of HD is what sets it apart from SD, not the aspect ratio. There is 16×9 SD and believe it or not, even 4×3 HD. And, as ZRB pointed out, HDV is HD, its just one of many compressed flavors of HD. I understand why you may not like to call it HD, but it is.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY
A forum host of Creative COW’s Business & Marketing, and Indie Film & Documentary forums.
