Activity › Forums › DVD Authoring › HD video looks HORRIBLE when put on DVD through DVDSP!!
  • HD video looks HORRIBLE when put on DVD through DVDSP!!
    Posted by Ben Con on July 25, 2014 at 4:29 pm
    I recently shot a video on a Sony XDCam PMW-EX3. I shot it 1920x1080i 60.
    I edited it in Final Cut Pro (7) and Exported using a variety for formats: MPEG-4, H.264, Prores 4444, Prores 422, ect. All exports came out looking clear on my monitor. The footage looks exactly how it did when I filmed it. I brought it into DVDSP and burned it to a DVD. The dvd looks HORRIBLE!! So grainy and overexposed its unwatchable! Does anyone know what I can do? Please, I need someone to help me with this!
    Final Cut Pro 7, iOS 6.1.6, MacPro
    Greg Ball replied 11 years, 12 months ago 4 Members · 6 Replies
  • Steve Brame
    July 25, 2014 at 5:26 pm
    First of all, you realize that your HD footage is being re-encoded to SD. If you are expecting a DVD to look like the original HD footage, you’re starting out at a disadvantage.
    I’d advise taking control of the conversion to SD by doing it yourself, instead of letting your authoring software handle that task for you.
    Asus P6X58D Premium * Core i7 950 * 24GB RAM * nVidia Quadro 4000 * Windows 7 Premium 64bit * System Drive – WD Caviar Black 500GB * 2nd Drive(Pagefile, Previews) – WD Velociraptor 10K drive 600GB * Media Drive – 2TB RAID0 (4 – WD Caviar Black 500GB drive) * Matrox MX02 Mini * Adobe CC
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
  • Ben Con
    July 26, 2014 at 2:40 pm
    Hey Steve
    Thanks for replying!
    Yes, I know. But like I said, somethings up, cause you can barely make out anything.
    How can i take control of the conversion in Final Cut Pro? if so, what format, ect.? or do I need another software for that?
    Do you know of any software to convert my footage that is free?
  • Steve Brame
    July 26, 2014 at 3:48 pm
    I don’t do Macs or FCP, so as far as a free solution, someone else will have to interject.
    DVDSP is automatically converting your footage to MPEG2 format, which is the DVD standard. I would imagine that DVDSP will allow you to tweak what settings it uses to do this, but again, I don’t do Macs.
    Steve Brame
  • Ben Con
    July 28, 2014 at 7:50 pm
    Ok I’ve tried and still looks really bad.
    Anyone got an idea??
  • David Rehm
    August 29, 2014 at 12:03 am
    Here is your solution. It’s going to seem complicated and intimidating but once you go through the process a time or two, it becomes easier.
    Even though you are going through many steps – in the end – this process is MUCH faster than letter your editing program encode, but yet the results will be pristine – yes pristine.
    https://www.precomposed.com/blog/2009/07/hd-to-sd-dvd-best-methods/
    https://www.precomposed.com/blog/2010/10/hd-to-sd-dvd-cs5-revisited/
    These videos will help you set things up and get going – step by step:
    https://bellunevideo.com/tutdetail.php?tutid=14
    https://bellunevideo.com/tutdetail.php?tutid=12
    Again, it is going to look like a big giant hassle and intimidate you but I swear you will not regret the final outcome.
    David
  • Greg Ball
    October 2, 2014 at 9:23 pm
    Just export your video out of FCP 7 as a self contained quicktime. The bring that into compressor. Use 90 minute best settings, and turn frame controls on. Adjust your bit rate to work best.
