Activity › Forums › Apple Final Cut Pro Legacy › HD varicam capturing problem
  • HD varicam capturing problem
    Posted by Venkat on October 10, 2007 at 4:43 am
    Hello experts!
    Let me give brief about my setup before I ask my question.
    I have Macpro.2.66GHZ dual core xeon machine.
    HD extreme capture card.
    Cal digit Raid with read & write speed of 234 & 210MB/s.,
    Final Cut Pro 6.
    AJ-HD1400E DVCPRO HD VTR
    Frame Rate-25 fps.
    My Issue is whenever I capture my footage from DVCPRO HD VTR with the frame rate of 25, 24, 30(I know these are fractional in Numbers) I don
    Matt Larson replied 18 years, 11 months ago 2 Members · 1 Reply
  • Matt Larson
    October 10, 2007 at 1:21 pm
    Have you tried capturing your 60 fps footage AT 60 fps? That’s what I would do if you are trying to use the slow motion from the camera. Then run that footage through the DVCProHD Frame Rate converter to slow down the playback. (In the “Tools” menu in FCP 6 and in the Extras folder on the install disk of earlier versions)
    You may need to contact BlackMagic to see if their card keeps the Varicam flags once digitzied because you will need those to slow down the clip. If not, digitize through Firewire.
