Activity › Forums › Blackmagic Design › HD upconvert….
  • HD upconvert….
    Posted by Craig Ernst on April 16, 2005 at 2:24 am
    I have a Decklink HD PRO and I was wondering if someone could give me a detailed explanation of how to Upconvert DVCAM footage to HDCAM vis SDI.
    Craig
    Adam Levine replied 21 years, 5 months ago 3 Members · 4 Replies
  • Adam Levine
    April 17, 2005 at 4:01 pm
    I prefer to do these things in AE, combustion or Commotion, as I find their scaling to be far superior to FCP. You will need to make an HD timeline/composition, put in your movie, and scale up. Also, to deal with the color issues:
    https://www.mimikri.ch/afx.html
  • Craig Ernst
    April 17, 2005 at 6:54 pm
    I really appreciate your response but I need to do this in FCP and the Decklink card has an option to do Upconvert.
    Craig
  • Dalen Quaice
    April 17, 2005 at 7:16 pm
    The Kona2 does real-time upconversion (and downconversion), but I thought the Decklink HD Pro only did downconversion. I may be missing something.
  • Adam Levine
    April 17, 2005 at 8:16 pm
    I may be missing something, but I don’t think DL does that. In any event, I believe it is sub-optimal. For example, if I were to convert an SD anamorphic program to 720P, I would export to a QT movie, bring into AE and drop it into a 24P SD comp, then use Magic Bullet to convert the frame rate. Then I would drop that comp into a 720P comp, apply Mimikri to adjust my color and render
