Activity Forums Compression Techniques HD uncompressed to MPEG 2 via Compressor rendering times
  • HD uncompressed to MPEG 2 via Compressor rendering times
    Posted by Dale Launer on January 31, 2006 at 6:17 am
    I have a movie – 1:45 (an hour 45 min), and when I do a two pass VBR crunch via Compressor – it takes about 36 hours to work it’s magic. This is with a G5 2 x 2.5ghz and 2 gigs of RAM.
    I’m using a AJA KONA Vuy codec (originally they were Cinewave YUV files).
    Is a day a half too long?
    I have another G5 – a 2x 2ghz – if I connect these via Qmaster – anyone know approximately how much improvement I would see?
    Dale
    Ben Waggoner replied 20 years, 7 months ago 2 Members · 1 Reply
  • Ben Waggoner
    February 9, 2006 at 7:46 am
    The big problem with QMaster is that your VBR gets worse the more nodes you have, since it does each VBR on each node independently.
