Activity › Forums › Apple Final Cut Pro Legacy › HD to SD Workflow
HD to SD Workflow
Posted by Derek Natzke on June 8, 2007 at 1:26 pmIs there a simple way using FCP and DVDSP to make a HD project into a SD DVD.
Chris Borjis replied 19 years, 3 months ago 3 Members · 3 Replies -
Chris Poisson
June 8, 2007 at 1:39 pmVery simple, very easy. Just export a QT movie, no need to make self-contained, and put it in Compressor. Choose a high quality encode for DVD, in the inspector you will see that it is set to 720×480 16×9.
You also can send your HD timeline to Compressor and encode the same way, but it will take longer, and the results might be cleaner.
Load your assets into DVDSP and choose to hve it letterboxed or widescreen. That’s it. Compressor will do all the scaling, etc.
Derek Natzke
June 8, 2007 at 2:15 pmThanks! Could you read my “Jitter Dissolve” post and see if you’ve had this issue?
Chris Borjis
June 8, 2007 at 3:52 pmyou may need to adjust the scaling in compressor to “best” otherwise you could very well have aliasing occur with the stock settings.
