Activity Forums Apple Final Cut Pro Legacy HD to SD PAL downconversion
  • HD to SD PAL downconversion
    Posted by Max Chernyaev on February 18, 2008 at 4:09 pm
    Hi!
    We’ve got a DVCPRO HD 720p25 master sequence. The goal is to downscale it to 720×576 anamorphic video for DigiBeta output with the most quality available.
    As I understand we are to render it for example to ProRes HQ, load it into Shake, downscale and export to an uncompressed 4:2:2. Is it the best method or you know better taking in count that it’s not a time-critical task, quality is more important? And what scale method would you recommend to use in the Transform node in Shake?
    Thank you in advance!
    Simon Blackledge replied 18 years, 7 months ago 4 Members · 4 Replies
  • Shane Ross
    February 18, 2008 at 6:08 pm
    DO you have an HD capture card? Decklink? AJA? They both downconvert very well when you output through them. Just do it that way. It’s what I do.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Russell Lasson
    February 18, 2008 at 8:52 pm
    I’ve also used compressor to downconvert, but it takes some experimenting with as your settings depend on your video.
    -Russ
    Russell Lasson
    Kaleidoscope Pictures
    Provo, UT
  • Max Chernyaev
    February 18, 2008 at 9:21 pm
    Yeah, but realtime downconvertion is the best way to save time, not the picture I guess. The best results in realtime you may experiecne only with KONA 3. We haven’t got it anyway.
  • Simon Blackledge
    February 19, 2008 at 7:27 am
    If doing it in Shake how are you compensating for the rec709 > 601 conversion ?
