Activity Forums Apple Final Cut Pro Legacy HD to SD flicking
  • HD to SD flicking
    Posted by Samer Mahmoud on September 17, 2011 at 6:32 pm
    i have a HD footage shot in Canon 5D, when down scaling it to SD i got some flicking when the camera moves.
    im using quick time conversion to down scale the footage, tried every possible option, but still have the same problem.
    when i play the quick time file using quicktime player it looks fine, but when i import it to FCP i get the problem.
    Samer Mahmoud replied 14 years, 10 months ago 3 Members · 4 Replies
  • Daniel Sametz
    September 17, 2011 at 8:31 pm
    Dos you convert it to Prores? Or it’s H.264?
  • Samer Mahmoud
    September 17, 2011 at 8:37 pm
    i did try 8 bits uncompressed, none, pro res (all), upper, off fields, played arround with the time line settings, but all the same
    in the past i had same problem, what i did is render the project as 1080i then render it back to SD, but that is too much render for long projects.
  • Pradip Patil
    September 18, 2011 at 9:46 am
    Try compressor. Use an SD format preset. Search here for tips on how to use compressor to get desired results. You will need to tweak frame controls settings for frame resizing.
    Pradip Patil
    Mumbai,India
  • Samer Mahmoud
    October 8, 2011 at 8:13 pm
    thanks i will try compressor, i fixed the problem using antiflicker filter, it made the image a little bit blury, but its only few wide shots, so no one woule notice 😀
