Activity Forums Avid Media Composer HD to SD export using maintain Aspect with crop in avid?
  • HD to SD export using maintain Aspect with crop in avid?
    Posted by Matt Pascale on June 8, 2010 at 9:24 pm
    I have a 1080 sequence. I need to export a copy of this sequence as a same as source SD 4:3 QT. In FCP there is a feature that allows you to export 4:3 and maintain the aspect ratio by cropping. Been utilizing this work flow for awhile. Now i need to do the same in AVID.
    However, i cannot get it to work properly… Under export settings/custom/ quicktime options you have the same exact dialog box as in fcp, but the exports are not properly cropped.
    There are 2 sets of options the ones in the avid export settings box and the ones in the qt options box. Ive tried many combinations and i always get either an anamorphic 4:3 image (scale to fit) or a blow up of the image inside the 4:3 space (crop/pad).
    Its not a square vs non square thing either because the full frame is there. The crop does not seem to be working. Any ideas?
    Matt Pascale replied 16 years, 3 months ago 1 Member · 1 Reply
  • Matt Pascale
    June 8, 2010 at 11:19 pm
    Sorry, I meant Im trying to export my 1080 sequence to Meridian compressed 2:1 NOT same as source as i stated above.
    Also, is this possible a Quicktime pro issue as this machine does not have Qt pro installed?
