Activity Forums Apple Final Cut Pro Legacy HD to SD down converting using Compressor – Best Results
  • HD to SD down converting using Compressor – Best Results
    Posted by Jesse Wenger on February 16, 2011 at 12:51 am
    I’m using The Final Cut Pro Compressor to down convert HD to SD for a 30min segment to put on a DVD to give to a local TV station to broadcast. The results have been disappointing. I have been using the trial and error method with no success.
    *I go into Compressor and maximize the Mbps settings (under the quality tab) to “Average – 7.6 Mbps” and “Maximum – 8.9 Mbps” (allowing 68 min of footage to be put on one DVD) and I use “two-pass VBS Best”.
    *I uncheck the box that says “Allow Job Segmenting”, because I don’t want it.
    *(in Frames) Resize Filter is set to “Best”.
    *Deinterlace is set to “Best”.
    *Rate Conversion is set to “Best”.
    *Does “Output Fields” need to be “Same As Source” or “Progressive” or “Bottom First” or “Top First”?
    *Should the “Adaptive Details” box be checked?
    ***What other settings should I place on here so it looks ok? I am still getting some motion blur and its driving me mad.
    What else do I need to do to make this look fine? Can anyone help me?
    I read this thread: “https://forums.creativecow.net/thread/8/1032896” – it’s about down converting, it wasn’t much help.
    I don’t care if my video has to render for 8-24 hrs, time isn’t a factor in getting a good quality product here. Should I fully render my video in final cut before I export it to compressor? Or does that not matter at all. I just don’t know what else I need to do and I have been spending weeks trying to fix this motion blur issue. Any help would is welcomed, thank you.
    Paul Jay replied 15 years, 7 months ago 3 Members · 2 Replies
  • Jerry Hofmann
    February 16, 2011 at 4:09 am
    Why are you deinterlacing it?
    What format is the HD? frame rate?
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Paul Jay
    February 16, 2011 at 11:13 am
    What is your SOURCE!!!!!
    Normally you want Same as Source.
    Just choose a preset.
    Change bitrate
    Resize filter to best.
    Done.
