Activity Forums Media 100 HD to SD conversion in M100?
  • HD to SD conversion in M100?
    Posted by Tahoe Todd on October 7, 2010 at 9:44 pm
    When importing HD media into M100 as SD 4×3, I cannot seem to find a method that does not either squeeze the footage or take a “cutout” of the original HD scene. This “cutout” is not squeezed but it cuts off part of the upper and lower portions of the original scene, as well as left and right. How can you import HD as SD without losing anything from the top and bottom of the scene?
    Thanks for your help!
    TahoeTHS
    Tahoe Todd replied 15 years, 5 months ago 5 Members · 19 Replies
  • 19 Replies
  • Floh Peters
    October 8, 2010 at 8:48 am
    Are you speaking about a file import, or about acquiring from tape?
  • Paul Crowe
    October 8, 2010 at 9:37 am
    dude,
    I have to admit, I’m curious as to why you’d actually want to do this?
    But I think for best results you may well have to use Compressor or Streamclip to transcode your footage to SD 4:3 (DV or whatever) and then import it into M100 to do your thing.
    Cheers
    Paul
  • Michael Slowe
    October 8, 2010 at 10:38 am
    What I would do (if you have to, see other post) is to take it into Media 100 as HD to start with and edit as HD on an HD timeline. Then open your 4:3 SD programme, drag the HD into it and the conform window will appear. You will be presented with the option of changing the framing within the 4:3 frame as you rightly say. But by crafty manipulation of the sliders (horizontal and vertical) you should be able to limit the ‘damage’ to your picture.
    Michael Slowe
  • Tahoe Todd
    October 8, 2010 at 3:14 pm
    Using a file…mov
  • Tahoe Todd
    October 8, 2010 at 3:16 pm
    To add new ftg to an existing 4×3 program…but I don’t want to shoot anything more in 4×3. Make sense?
    Thanks bro.
  • Tahoe Todd
    October 8, 2010 at 3:17 pm
    OK Michael, I’ll try that procedure and let u know.
  • Olof Ekbergh
    October 9, 2010 at 1:50 pm
    I work on a lot of legacy projects that are 4:3 60i SD, this is my workflow:
    I work with 30p XDcam and 5DmkII clips a lot.
    I preview and pick the clips in FCP. Even put together short sequences there, and do some Color round tripping in FCP even.
    Then I export as ProRes422 1080p.
    I batch import all those files into a my legacy M100 project, as HD still, they just update most of the time.
    Then I create a 4:3 30p timeline and drop all the clips into it. I conform them into 4:3 30p there. Uncheck the reacquire later box.
    Then I drag all those clips (one by one, to avoid creating a compound clip) into a new bin labeled SD 30P.
    Those clips are then ready to be dropped into a 60i timeline, just interpret them as interlaced.
    I know this may seem to be a pain, but it works very well. Unfortunately M100 can not conform media to 4:3 SD footage on import without crashing. That is why these steps are necessary.
    Be careful about mixing Prores and M100 lossless codecs, there is a big gamma shift. Set project up as one or the other and stick with it.
    Olof Ekbergh
  • Tahoe Todd
    March 11, 2011 at 4:35 pm
    Olof:
    Thanks for the educated advise!
    Here’s another situation…I’ve since moved into Final Cut Pro v6 and exported a Media100-suite timeline via XML for the first time. It came over to FCP fine, but the scenes seem to have gone through a severe color shift…everything is somewhat “washed-out” looking as compared to the way it looked in M100. I’m using a high-end HD monitor which is setup correctly. Any experience with this?
    Todd
  • Tahoe Todd
    March 11, 2011 at 4:44 pm
    BTW…I went to Pierce-Birchmont during the summers when I was a kid…loved it up there!
  • Floh Peters
    March 11, 2011 at 4:47 pm
    [Todd Simon] “Here’s another situation…I’ve since moved into Final Cut Pro v6 and exported a Media100-suite timeline via XML for the first time. It came over to FCP fine, but the scenes seem to have gone through a severe color shift…everything is somewhat “washed-out” looking as compared to the way it looked in M100. I’m using a high-end HD monitor which is setup correctly. Any experience with this?
    Are you using a Media 100 codec (Media 100 HD or Media 100 i)? This would explain it, since FCP handles these codecs incorrectly. FCP treats them as being full range 0-255, while they are StudioRange (16-235)
