Activity › Forums › DVD Authoring › HD to SD Anamorphic Question
  • HD to SD Anamorphic Question
    Posted by Marni Page on March 5, 2009 at 4:23 pm
    I’m making an SD Anamorphic 16:9 DVD from HDV material and I have a question.
    Could someone tell me if the overscan areas will or will not be seen on a widescreen TV using a DVD player that up-res’s the image to 1080i?
    Then I also want to confirm that when the image appears letterboxed on an SD 4:3 TV that the overscan on the sides remains out of frame while the top and bottom (of course) remain in the picture.
    Thanks for your help.
    Jon Geddes replied 17 years, 7 months ago 3 Members · 3 Replies
  • Michael Sacci
    March 5, 2009 at 4:35 pm
    TVs handle overscaning differently. As a practice there should never be anything in the overscan picture that you don’t want viewed while everything that needs to be viewed should fall within action or title safe. I would never rely on overscanning to eliminate poor framing of a shoot.
    Most playback on computers play the entire image.
  • Marni Page
    March 5, 2009 at 4:51 pm
    Actually, I wanted to shrink my image by about 1% and include as much of the overscan as possible. I know it varies and I run the risk of showing black around the edges if I shrink it too much. But just wanted to see if this was a workable solution because I shot something a bit too tight in HDV, you know what I mean and I need it to breathe just a little bit.
  • Jon Geddes
    March 5, 2009 at 5:28 pm
    If the DVD Player is connected digitally (with an HDMI cable) then you will see the entire frame. If it is connected with analog cables (Component, S-Video, Composite) then you will lose some of the frame to overscan.
    Jon Geddes
    Motion Graphics Designer
    http://www.precomposed.com
