Activity Forums Apple Final Cut Pro Legacy HD to SD aliasing artifacts
  • HD to SD aliasing artifacts
    Posted by Chris Stevens on April 6, 2009 at 10:39 am
    I’m a new convert to Final Cut from Media 100, so forgive me if I ask foolish questions!
    Successfully edited a native XDCAM EX sequence & all looks fine. Exported to compressor & encoded a 10 bit uncompressed quicktime. Result looks aliased? Should I experiment with the scaling settings or is there a better way?
    Cams: Z1, EX3, HDX900.
    Post :FCS6, Media 100HD V12, AE7, 12TB Sata Raid & monitoring to die for!
    Chris Borjis replied 17 years, 4 months ago 3 Members · 6 Replies
  • Walter Biscardi
    April 6, 2009 at 10:54 am
    What are you trying to accomplish with this method? Mastering your HD timeline to tape or to create a DVD?
    The absolute best and cleanest way to downconvert HD to SD is via hardware like the AJA Kona series. It’s also done in realtime with zero rendering required. We regularly edit HD material that is downconverted and mastered to BetaSP and DigiBeta tape in realtime via our Kona 3’s.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Chris Stevens
    April 6, 2009 at 11:14 am
    Thanks for the speedy response Walter.
    Currently running FCP without hardware. Trying to make SD DVD from HD sequence.
  • Walter Biscardi
    April 6, 2009 at 12:01 pm
    [Chris Stevens] “Trying to make SD DVD from HD sequence. “
    https://forums.creativecow.net/faq/applefinalcutpro#52
    Read my Blog!
  • Chris Borjis
    April 6, 2009 at 4:13 pm
    Chris go into your compressor setting and make sure
    the resize filter is set to best.
    that makes a HUGE difference.
  • Chris Stevens
    April 7, 2009 at 8:58 am
    Thank you Chris. Resize set to best worked fine. Is it ever worth playing with the antialiasing & detail settings? Or should I leave well alone?
  • Chris Borjis
    April 7, 2009 at 5:31 pm
    [Chris Stevens] “Is it ever worth playing with the antialiasing & detail settings? Or should I leave well alone?”
    leave em be. they usually make things worse.
