Activity Forums Adobe After Effects HD to SD 4:3 Comps script??
  • HD to SD 4:3 Comps script??
    Posted by Jeremy Kemp on September 2, 2010 at 5:48 am
    Is there a script that will assist in converting HD compositions to NTSC 4:3? The compositions are simple shape layers, no video is involved. I could swear I have used a script in the past for this, but cannot for the life of me find one now. I seem to recall it being from video copilot maybe?
    It is possible that the script I used was just for converting 16:9 to 4:3 and vice versa.
    Have a client that has requested all the work we did in HD to be converted to 4:3 without letterbox. Obviously the simplest solution would be to drop it onto a 4:3 timeline and scale it up to fit full frame, but then we will have title safe issues. Since they are only shape layers, it may not be a problem to just resize my shape layers, but there are several comps and want to spend as little time on it as possible.
    Can anyone give me some advice on the best way to go about this? Thanks!!
    Walter Soyka replied 15 years, 12 months ago 3 Members · 5 Replies
  • Chris Wright
    September 2, 2010 at 7:55 am
    You can anamorphically squeeze or have black areas or pan and scan or redo some parts because you might need to go manual tweaking while working in the 16:9 aspect ratio. There’s a new 4:3 center cut safe area visible (with the title/action safe overlays). For future reference, here’s a good read.
    https://forums.creativecow.net/thread/2/985426#985447
    and you can batch process all this with
    https://aescripts.com/batchprocessor/
    https://technicolorsoftware.hostzi.com/
  • Walter Soyka
    September 2, 2010 at 2:02 pm
    [Jeremy Kemp] “Obviously the simplest solution would be to drop it onto a 4:3 timeline and scale it up to fit full frame, but then we will have title safe issues. Since they are only shape layers, it may not be a problem to just resize my shape layers, but there are several comps and want to spend as little time on it as possible.”
    Unless you designed for a 4:3 title safe area, I don’t think an automated solution is feasible. I’d duplicate your original 16:9 comp, use the 4:3 overlay, redesign and reposition elements as necessary, and then drop it in your 4:3 comp for render.
    Walter Soyka
  • Jeremy Kemp
    September 2, 2010 at 4:31 pm
    Last night I went into the scripts folder and realized that the script I used in the past was the “Scale Comp” Script. It gave me the option to resize by Width or Heighth. I set the width to 720 and then went into my comp settings and changed the height to 480, chose DV NTSC and it looks like it adjusted everything almost perfectly. Everything is in the title safe. Needed a couple slight adjustments here and there, but I think this solution has worked.
    Does anyone know of anything I need to watch out for here or see any danger doing it this way?
    Thanks for all your help!
  • Jeremy Kemp
    September 2, 2010 at 5:02 pm
    Before using script…
    1058_picture3.png.zip
    After using script…
    1059_picture4.png.zip
  • Walter Soyka
    September 2, 2010 at 5:22 pm
    Scale Comp is a great script. As long as you’ve manually adjusted any misplaced elements, you should be ok. That said, be careful about going from square pixels to non-square. Double check all your PARs.
    For future reference, the COW can embed images right in your post for you if you don’t zip them before uploading.
    Walter Soyka
