Activity Forums Adobe Encore DVD HD to SD
  • HD to SD
    Posted by Guille Ibanez on August 12, 2010 at 11:07 am
    I have a project that i burn to Blu-ray (21gb). Now, I want to burn the same project into a DVD. I know that i can do this as i’ve done it in the past changing the disc type and project settings but now…..the problem is i had never had such a big blu ray project and when i try to burn it to DVD the project goes over 5gb therefore too big for a single DVD. Is there a way to reduce the size of the transcoding? lower the quality so it fits (like in DVD Architect)? otherwise, do i have to have two different files one for HD and another SD?
    thanks in advance
    Mathias Moyo replied 15 years, 11 months ago 5 Members · 4 Replies
  • Ann Bens
    August 29, 2010 at 12:33 am
    Dual layer?
  • Phil Grimpo
    September 2, 2010 at 9:09 pm
    I’ve had the same problem. The only way I found around it was to change the entire project type to a DVD project. It’s a real pain. I guess I’d figure that if I tell it to fit on a 4.7GB DVD, it should figure out how to compress to make it fit… just like it did in previous versions. Does anyone else have a way to do this without having to convert the project, or create a new one?
    _______________________
    Phil Grimpo
    Inspirmedia
    https://www.Inspirmedia.com
  • Diego Buenaño
    September 2, 2010 at 10:26 pm
    You try Blufish Epoch or Create Cards. They have a downscaler, 12 bit. Pristine quality.
    Hope it helps.
  • Mathias Moyo
    October 13, 2010 at 4:29 pm
    why dont you try DVD Shrink when your projects gets bigger than 4.7GB
