Activity › Forums › Apple Final Cut Pro Legacy › HD to Pal
HD to Pal
Posted by Johan Moeskops on December 11, 2006 at 6:21 pmHi.
Does someone know the best way to convert DVCPro HD 720 to DVD Pal 720×576
Thanks in advance.
regards, Johan
Johan Moeskops replied 19 years, 9 months ago 2 Members · 4 Replies -
Johan Moeskops
December 12, 2006 at 7:56 amHi Jeremy.
The framerate is 25 ( DVC Pro 720P 25 )
Regards, Johan
Jeremy Newmark
December 12, 2006 at 7:00 pmJohan,
This can be done pretty easily, since you are dealing with the same frame rate. The best way would be to take it to a dvd authoring house and have it encoded with a high-end hardware encoder (ie. Sonic, Digital-Rapids, etc.) However you can simply use compressor to encode the DVCPro to mpeg2 for dvd. You may want to search the archives of the DVD authoring, Sonic and DVD Studio Pro forums. There is a lot of info there that can probably get you going in the right direction. Hope this helps.
Best Regards,
jeremy
Johan Moeskops
December 12, 2006 at 7:11 pmHi Jeremy.
Yes, that helps.
Thanks a lot.regards, Johan
