Activity Forums Apple Final Cut Pro Legacy HD to DVD -Chronic Confusion
  • HD to DVD -Chronic Confusion
    Posted by Chris Babbitt on December 11, 2009 at 6:45 pm
    OK, so I’m not the sharpest pencil around here, but please bear with me one more time.
    I have a project that was shot and edited in 720 60p, and I’m making an SD-DVD. I assume most people will be watching this on progressive TVs, so I’d like to make a progressive DVD. Compressor, however, is forcing me to select a frame rate of 29.97. I assume this is because of the DVD spec, but it cuts my frame rate in half, and I lose the fluid motion on pans, etc. My other option is to go with an interlaced DVD, in which case, my motion is smoother, but the image is softer. I would take the fluid motion over the crisper image, but I’d like to have both. Is that possible?
    If I decide on an interlaced DVD, would it have been better if I would have shot in interlaced as well?
    Michael Sacci replied 16 years, 9 months ago 5 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    December 11, 2009 at 6:52 pm
    Sorry…but all SD formats are 29.97. That’s the simple truth. TVs are 29.97…well, some now have higher Hz rates for ultra smooth playback, but all DVD players are 23.98 or 29.97. I think even BLURAY only goes as high as 29.97. 59.94 (60fps) is not a broadcast format. Shooting, yes. You can deliver a 60p master, yes…but all is converted to 29.97 in the end.
    Shane
  • Michael Sacci
    December 11, 2009 at 8:27 pm
    Shooting 60p gives you good clean 29.97i (since there are 59.94 interlaced fields) it is cleaner than if you shoot 30p.
    60p gives you the best of both worlds so unless you want the 24p look it is recommended for 720p, at least in my thinking.
    You may want to do a short test with the Frame Control filter turn on (set to best) it takes a long time to encode but you may get a lot sharper image with the interlaced footage.
  • Chris Babbitt
    December 11, 2009 at 8:40 pm
    Thanks Michael. I’ll try the high setting. Are you speaking of the resize filter, the rate conversion or both?
    So, I’m assuming that the only reason for producing a progressive DVD is if you want the 24p look?
    Would you still recommend shooting 60p over 60i if going to an interlaced DVD?
  • Chris Borjis
    December 11, 2009 at 9:48 pm
    [Shane Ross] “I think even BLURAY only goes as high as 29.97”
    to help those that might be reading this Blu-Ray only supports:
    720P 23.98
    720P 59.94
    1080i 29.97 (1080P 29.97 is not supported oddly though HD-DVD did)
    1080P 23.98
  • Chris Borjis
    December 11, 2009 at 9:50 pm
    just a note that going from 720P to SD with compressor
    even on the highest quality setting you might see
    jagged aliasing on angles (roof lines for example).
    I once had to do a live down-convert via kona hardware
    to remedy that for a DVD.
    if you have a kona card and can play it out to do
    the conversion you should it will be much quicker
    and better looking. It would likely also solve your frame rate boggle.
  • Alan Okey
    December 11, 2009 at 9:53 pm
    [Chris Babbitt] “So, I’m assuming that the only reason for producing a progressive DVD is if you want the 24p look?
    Would you still recommend shooting 60p over 60i if going to an interlaced DVD? “
    Two benefits of progressive footage:
    1. If 24p, there’s a space savings on a DVD of 20% vs. 29.97i or 30p. Also, at a given average bit rate, bit allocation will be proportionally higher per frame given the fewer number of frames per second.
    2. Progressive frames generally encode with better results than interlaced frames in MPEG-2 compression.
    However, if you don’t want a progressive look (24p or 30p), stick with 720p60.
    Consumer LCD and plasma TVs have built-in hardware deinterlacing, which essentially turns 29.97i into 60p. If you shoot 720p60 and downconvert to a 29.97i DVD, the result on a consumer LCD or plasma TV will retain the “live” look of 60p.
    Assuming you’re not using a Teranex hardware converter for downconversion, 720p60 will give better results than 1080i29.97 when downscaling to SD 29.97i because no field scaling/interpolation will be necessary.
  • Chris Babbitt
    December 11, 2009 at 10:09 pm
    Great information. Thank you. Actually, even though the interlaced DVD looks a little softer compared to the progressive DVD, it still looks good, and may even look better to people who leave their TVs set to the factory settings. The factory settings generally have the sharpness, contrast and chroma cranked up. When I view the progressive DVD on my set with the standard factory setting, I get a sharper, but also noisier image than with the interlaced DVD.
  • Michael Sacci
    December 12, 2009 at 5:04 am
    60p gives you more options since 29.97 has 60 field it is a clear conversion, all it needs to do it drop every other line on each progressive field to give you the same thing as you would have got it you had shoot it 27.97i. The same cannot be said for going from 29.97i to 60p.
    So if you need to convert the footage to 1080i or 1080p it would be cleaner also.
    And since progressive is the way 720p was meant to be shot I just don’t see why you would not shoot it as progressive.
    I would do several test, Resize at Better and best, if you are dc to SD NTSC make sure you choice Bottom First in output fields. Then I would play with the anti-alias and detail sliders until you get a best results. These are more important when up-converting but they still can help with downconverting.
    Once again use short segment of the video in question. A good piece with action and detail. Compressing is an art and if you want better results you have to put in the effort.
