Activity Forums Adobe After Effects HD Titles
  • Posted by Andy Niblo on June 11, 2011 at 4:48 pm
    Hi Community,
    I have recently been doing the opening and closing titles for my film and have hit a couple of niggles.
    Diagonal lines are not smooth, they show a slightly pixellated edge. I made then in AE and exported them in 1920×1080 Apple Pro Res.
    Any solutions on how to make these jagged edges disappear?
    Hope you can help.
    Thanks very much
    Andy 🙂
    All Northern
    Andy Niblo replied 15 years, 2 months ago 3 Members · 4 Replies
  • Joey Foreman
    June 12, 2011 at 10:32 pm
    When you say exported, do you mean rendered?
    Does the text look pixellated in the comp before rendering?
    Are you positive you’re rendering at full quality?
    How are you viewing the rendered result?
    Joey Foreman
    Editor/Compositor/VFX Artist
  • Michal Trzaska
    June 15, 2011 at 10:51 pm
    mhhhhh, this sounds like interlacing to me. or quality issue.
    Composition Settings>resolution should be full
    Render Queue in Render Settings Make sure Field Render is Off to get a progressive signal.
    Render Queue in Output Module Settings go to Format Options under the Video Output section. In the Codac Settings make sure that “Interlaced” is off
    Try that see if that gets you better results.
    Best of luck,
    Michal Trzaska
    Editor, Colorist, Director of Photography, VFX Artist and Motion Graphics Artist
    MeHow Design
    TV Commercials for your Google TV ads. Web Videos that get results
    2011 Demo
  • Andy Niblo
    June 17, 2011 at 8:03 pm
    [Joey Foreman] “When you say exported, do you mean rendered?
    How are you viewing the rendered result?”
    Yeah, it’s rendered out, and i can see some jaggyness on the diagonals, but I have set the quality to best in the layer window.
    The rendered results look fine on my mac monitor, but when we boost the signal and view it on an external monitor the problem in much more visible.
    Cheers Michal, will give that a try. Will let you know if it works.
    Andy 🙂
    All Northern
  • Andy Niblo
    June 17, 2011 at 8:38 pm
    Followed the steps but still no difference, unfortunately.
    Any other ideas? I think it is an aliasing problem. Tried applying a mask too, but the feather doesn’t fit aesthetically. It needs to be hard lines.
    Cheers
    Andy 🙂
    All Northern
