Activity Forums Apple Final Cut Pro Legacy HD timeline codec
  • HD timeline codec
    Posted by Jeffchamlee on June 7, 2007 at 1:14 pm
    What’s the best sequence preset to use when importing uncompressed HD 1080p 3d animation files? I’ve tried setting the sequence to use ‘QT animation but it takes forever to render and pretty much kills the system. i’m wondering if i use the DVCPro HD setting if it will run smoother? If I understand correctly, the sequence compression and the final output compression are totally seperate. in other words, i can still render an ‘uncompressed’ or ‘animation’ QT file for the highest output quality, but use compression for editing the sequence in the timeline.
    thanks for any clarification…
    Chris Borjis replied 19 years, 3 months ago 2 Members · 1 Reply
  • Chris Borjis
    June 7, 2007 at 3:42 pm
    [jeffchamlee] “What’s the best sequence preset to use when importing uncompressed HD 1080p 3d animation files?”
    10-bit uncompressed is the best.
